Tonkinite
Aug 08, 2017Luminary
LACP no longer working on RN516 running 6.7.5
LACP bonding no longer seems to work with my RN516 on 6.7.5, the switch shows only one interface up, as if the teaming is Active Backup, not LACP. The MTU keeps resetting to 1500 from 9000, as if th...
Marty_M
Aug 09, 2017NETGEAR Employee Retired
Hello Tonkinite,
Was teaming mode working fine before and the problem just recently occured? Did the NAS encounter anything on the network that may have cause this behavior of the NAS. You may check this thread for additional information.
Marty_M
NETGEAR Community Team
- TonkiniteAug 09, 2017Luminary
Teaming was last setup and verified on 6.6.1, with the switch at the previous minor release. Not verified on the upgrade to 6.7.2, 6.7.4 & 6.7.5, so could have faltered somewhere along the way.
Both links are lit up on both ends, so no obvious problem with the hardware, and I swapped out the cables as well, no difference.
l skimmed the system log, and there does appear to be signs of a problem, but it's not clear what. I can try changing the teaming mode to something else, and then back to see if that helps.
Likely a bug, hopefully is/will be addressed in 6.8 releases.
- Marty_MAug 10, 2017NETGEAR Employee Retired
Hello Tonkinite,
There is no specific information on the release notes of firmware version 6.8.0 about the teaming/bonding on the NAS. The 6.8.0 firmware version had been already officially release you may want to try it and check if it will make any difference.
Marty_M
NETGEAR Community Team- TonkiniteAug 10, 2017Luminary
Changed the teaming mode to Round Robin, which seemed to allow the Jumbo frame MTU to stick, even after switching back to LACP, but the switch still only shows one line active (but the opposite one now).
Tried to manually install 6.8.0, it failed with "Unrecognized server error", even though it's a local install.
- StephenBAug 10, 2017Guru - Experienced User
That one's new to me (and I haven't seen that error with my NAS). What browser were you using? At what point in the process did it fail?
- Marty_MAug 13, 2017NETGEAR Employee Retired
Hello Tonkinite,
Upgrading the firmware did not make any difference and the problem persists. Can you please give us a copy of the complete logs of the NAS, you may use any file sharing website like wikisend and just PM the download link.
Marty_M
NETGEAR Community Team- TonkiniteAug 13, 2017Luminary
Have moved Zip of logs to DropBox, will post a link to you as a private message.
If you find anything of concern, please let me know.
Thanks!
