Tonkinite
Aug 08, 2017Luminary
LACP no longer working on RN516 running 6.7.5
LACP bonding no longer seems to work with my RN516 on 6.7.5, the switch shows only one interface up, as if the teaming is Active Backup, not LACP. The MTU keeps resetting to 1500 from 9000, as if th...
Marty_M
Aug 09, 2017NETGEAR Employee Retired
Hello Tonkinite,
Was teaming mode working fine before and the problem just recently occured? Did the NAS encounter anything on the network that may have cause this behavior of the NAS. You may check this thread for additional information.
Marty_M
NETGEAR Community Team
Tonkinite
Aug 09, 2017Luminary
Teaming was last setup and verified on 6.6.1, with the switch at the previous minor release. Not verified on the upgrade to 6.7.2, 6.7.4 & 6.7.5, so could have faltered somewhere along the way.
Both links are lit up on both ends, so no obvious problem with the hardware, and I swapped out the cables as well, no difference.
l skimmed the system log, and there does appear to be signs of a problem, but it's not clear what. I can try changing the teaming mode to something else, and then back to see if that helps.
Likely a bug, hopefully is/will be addressed in 6.8 releases.
