Tonkinite
Aug 08, 2017Luminary
LACP no longer working on RN516 running 6.7.5
LACP bonding no longer seems to work with my RN516 on 6.7.5, the switch shows only one interface up, as if the teaming is Active Backup, not LACP. The MTU keeps resetting to 1500 from 9000, as if th...
Marty_M
Aug 15, 2017NETGEAR Employee Retired
Hello Tonkinite,
Upon checking the logs I cannot find anything relevant that may cause this behavior of the NAS. Have you tried removing the bond and then re-creating it after the firmware upgrade? You can also try to remove the bond then observe each ethernet port connection if it will be stable or not.
Marty_M
NETGEAR Community Team
Tonkinite
Aug 15, 2017Luminary
Yes, made no difference on either firmware level, switch shows only one link active, unlike on the RN626X, where both links show active.
