zhenya
Jan 16, 2015Aspirant
losing connection to ReadyNAS Duo
I am running ReadyNAS DUO and lately started experiencing connection issues. All of sudden I can't access my shares from any system on the network. I am getting the following error.
Restoring Network Connections
An error occurred while reconnecting V: to
\\readynas\Data
Microsoft Windows Network: The local device name is already in use.
This connection has not been restored.
I still have access to the web management interface and Netgear reboot will solve the problem. Sometimes the fix stays for only few hours and sometimes it's good for days.
Any ideas of what's going on?
\\readynas\Data
- zhenyaAspirantGot it. Thanks.
ReadyNAS:~# df -h /
Filesystem Size Used Avail Use% Mounted on
/dev/hdc1 1.9G 1.9G 66M 97% /
ReadyNAS:~# df -i /
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/hdc1 256000 14727 241273 6% / - StephenBGuru - Experienced UserYour OS partition is almost completely full. So you need to find which files are filling it.
Tryls -l -h /
ls -l -h /var/logs
If /var/logs is not where the problem is, you can use the ls -l -h / command to find the biggest directory.
Then search that directory until you find where the problem is. - zhenyaAspirantThank you Stephen. I found the offending file upnp-av.log was nearly 1.6Gb. Here is the new output. Hopefully this solves the problem. Thank you for your help.
ReadyNAS:/# df -h /
/dev/hdc1 1.9G 410M 1.5G 21% /
ReadyNAS:/# df -i /
/dev/hdc1 256000 14708 241292 6% / - StephenBGuru - Experienced UserMuch better!
Hopefully that will resolve the connection problem.
