CDStoneley
Jun 08, 2017Aspirant
'Management service is offline' after 6.7.4 upgrade
I inadvertantly kicked off the firmware update to 6.7.4, and now although my RN314 has rebooted, and the display cycles between displaying ReadyNAS 314 6.7.4 and displaying the current state...
- Jun 08, 2017
You may have run into an issue fixed by 6.7.5 Beta 1
You could download the firmware update and install it via https://ip.address.of.nas/fwbroker
mdgm-ntgr
Jun 08, 2017NETGEAR Employee Retired
CDStoneley
Up and running on the Beta. Thank you.
I had a phantom old Volume which i had to delete (some SSD experiments) and it seems I have to share my primary shares on the RN314 volume again, but I'm running again. Many thanks!
Chris
- Jun 10, 2022Retired_Member
