CDStoneley
Jun 08, 2017Aspirant
'Management service is offline' after 6.7.4 upgrade
I inadvertantly kicked off the firmware update to 6.7.4, and now although my RN314 has rebooted, and the display cycles between displaying ReadyNAS 314 6.7.4 and displaying the current state...
- Jun 09, 2017
You may have run into an issue fixed by 6.7.5 Beta 1
You could download the firmware update and install it via https://ip.address.of.nas/fwbroker
Jun 21, 2017Guru - Experienced User
nativevml wrote:
I have critical data on the drives so I cant afford a reset.
Then the first step is to back that data up right away.
After that, likely the fastest way to get this resolved is to use paid netgear support (my.netgear.com). There is a per-incident support option that gets you one hour of support time.
Does https://nas-ip-address/fwbroker respond? Use the real NAS IP of course.
nativevml
Jun 22, 2017Aspirant
Hey Stephen,
yes that does respond.
- StephenBJun 22, 2017Guru - Experienced User
Good. Try installing 6.7.5 using that interface. There are some fixes that might apply (though it is not guaranteed) https://kb.netgear.com/000038857/ReadyNAS-OS-6-Software-Version-6-7-5
Unzip the download, and only install the img file.
- nativevmlJun 22, 2017Aspirant
I sent my Logs to Marty, should I wait for his response first?
- nativevmlJul 03, 2017Aspirant
:smileyvery-happy:
StephenB wrote:
nativevml wrote:yes that does respond.
DUDE!!! I did the https://x.x.x.x/fwbroker and it worked!!!! thank you to Marty_M and StephenB and mdgm-ntgr :smileyvery-happy:
