CDStoneley
Jun 08, 2017Aspirant
'Management service is offline' after 6.7.4 upgrade
I inadvertantly kicked off the firmware update to 6.7.4, and now although my RN314 has rebooted, and the display cycles between displaying ReadyNAS 314 6.7.4 and displaying the current state...
- Jun 08, 2017
You may have run into an issue fixed by 6.7.5 Beta 1
You could download the firmware update and install it via https://ip.address.of.nas/fwbroker
Jun 22, 2017Guru - Experienced User
nativevml wrote:
yes that does respond.
Good. Try installing 6.7.5 using that interface. There are some fixes that might apply (though it is not guaranteed) https://kb.netgear.com/000038857/ReadyNAS-OS-6-Software-Version-6-7-5
Unzip the download, and only install the img file.
- Jun 10, 2022Retired_Member
