CDStoneley
Jun 08, 2017Aspirant
'Management service is offline' after 6.7.4 upgrade
I inadvertantly kicked off the firmware update to 6.7.4, and now although my RN314 has rebooted, and the display cycles between displaying ReadyNAS 314 6.7.4 and displaying the current state...
- Jun 08, 2017
You may have run into an issue fixed by 6.7.5 Beta 1
You could download the firmware update and install it via https://ip.address.of.nas/fwbroker
Jun 21, 2017Guru - Experienced User
nativevml wrote:
I have critical data on the drives so I cant afford a reset.
Then the first step is to back that data up right away.
After that, likely the fastest way to get this resolved is to use paid netgear support (my.netgear.com). There is a per-incident support option that gets you one hour of support time.
Does https://nas-ip-address/fwbroker respond? Use the real NAS IP of course.
laithabdul
Jun 29, 2017Aspirant
Hi
after used https://ip-readynas/fwbroker
i get this message
ERROR 6001010006
Couldn't resolve host name
- StephenBJun 29, 2017Guru - Experienced User
Where are you seeing this message?
- laithabdulJun 30, 2017Aspirant
Hi
I have readynas4220
firmware : 6.7.4
status : management service is offline
when use https://nas-ip-address
request username and password after give user and pass i get connecting to the ReadyNAS Admin Pageafter used https://nas-ip-address/fwbroker
i get this message
ERROR 6001010006
Couldn't resolve host name- StephenBJul 01, 2017Guru - Experienced User
Is this after you upload/install the firmware? Or when you try to upload/install the firmware?
- Jun 10, 2022Retired_Member
