CDStoneley
Jun 08, 2017Aspirant
'Management service is offline' after 6.7.4 upgrade
I inadvertantly kicked off the firmware update to 6.7.4, and now although my RN314 has rebooted, and the display cycles between displaying ReadyNAS 314 6.7.4 and displaying the current state...
- Jun 08, 2017
You may have run into an issue fixed by 6.7.5 Beta 1
You could download the firmware update and install it via https://ip.address.of.nas/fwbroker
Jun 29, 2017Guru - Experienced User
Where are you seeing this message?
laithabdul
Jun 30, 2017Aspirant
Hi
I have readynas4220
firmware : 6.7.4
status : management service is offline
when use https://nas-ip-address
request username and password after give user and pass i get connecting to the ReadyNAS Admin Page
after used https://nas-ip-address/fwbroker
i get this message
ERROR 6001010006
Couldn't resolve host name
- StephenBJul 01, 2017Guru - Experienced User
Is this after you upload/install the firmware? Or when you try to upload/install the firmware?
- laithabdulJul 01, 2017Aspirantafter upload and install the firmware
In some past posts, this was linked to quotas being enabled on a volume with a lot of snapshots.
Try rebooting the NAS - if that doesn't help, try to do an OS reinstall from the front panel. With current firmware the OS reinstall should clear the volume quota setting. It also resets the admin password to password and the network configuration to use DHCP. Data and other settings shouldn't be affected.
- Jun 10, 2022Retired_Member
