CDStoneley
Jun 08, 2017Aspirant
'Management service is offline' after 6.7.4 upgrade
I inadvertantly kicked off the firmware update to 6.7.4, and now although my RN314 has rebooted, and the display cycles between displaying ReadyNAS 314 6.7.4 and displaying the current state...
- Jun 08, 2017
You may have run into an issue fixed by 6.7.5 Beta 1
You could download the firmware update and install it via https://ip.address.of.nas/fwbroker
Jul 01, 2017Guru - Experienced User
Is this after you upload/install the firmware? Or when you try to upload/install the firmware?
laithabdul
Jul 01, 2017Aspirant
after upload and install the firmware
- StephenBJul 01, 2017Guru - Experienced User
In some past posts, this was linked to quotas being enabled on a volume with a lot of snapshots.
Try rebooting the NAS - if that doesn't help, try to do an OS reinstall from the front panel. With current firmware the OS reinstall should clear the volume quota setting. It also resets the admin password to password and the network configuration to use DHCP. Data and other settings shouldn't be affected.
- laithabdulJul 01, 2017AspirantI dont have data How do OS reinstall from front panel and how resets to default Thanks
- StephenBJul 02, 2017Guru - Experienced User
The boot menu options for the 4220 rackmount ReadyNAS are on page 33-34 here: http://www.downloads.netgear.com/files/GDC/RN2120/ReadyNAS_OS_6_Rackmount_HW_UM_10Dec2014.pdf
- laithabdulJul 03, 2017Aspirant
I did the same steps and did not return defualt
- StephenBJul 03, 2017Guru - Experienced User
If you want to do a factory default, another way is to zero or unpartition the disks. For instance, connect the drives to a windows system, run the windows disk manager, and then delete all the partitions ("volumes" in windows parlance) on the drives.
- laithabdulJul 04, 2017Aspirant
I want to do a factory default readynas rn 4220.
I want any way to access the readynas
Thanks
- StephenBJul 04, 2017Guru - Experienced User
There are two ways I described earlier in this thread
- boot menu
- power down, unformat all the disks, then power up
Did you try either of those?
The first method (boot menu) did not work
The second methode (unformat all the disks) I did not understand it needs more detailThanks
- StephenBJul 05, 2017Guru - Experienced User
- Connect each disk to a windows PC (USB or SATA).
- Open the windows disk manager (entering diskmgmt.msc on the run line will work).
- At the bottom of the disk manager window you will see each disk in the system. There's a graphic next to each disk that shows every partition (which Windows calls "volumes" for some reason).
- Right click on each partition in the graphic, and select "delete volume"
- Put all the disks back into the unpowered NAS and turn it on. It will do a factory install (since all the disks are blank).
- Jun 10, 2022Retired_Member
