CDStoneley
Jun 08, 2017Aspirant
'Management service is offline' after 6.7.4 upgrade
I inadvertantly kicked off the firmware update to 6.7.4, and now although my RN314 has rebooted, and the display cycles between displaying ReadyNAS 314 6.7.4 and displaying the current state...
- Jun 08, 2017
You may have run into an issue fixed by 6.7.5 Beta 1
You could download the firmware update and install it via https://ip.address.of.nas/fwbroker
laithabdul
Jul 04, 2017Aspirant
The first method (boot menu) did not work
The second methode (unformat all the disks) I did not understand it needs more detail
Thanks
Jul 05, 2017Guru - Experienced User
- Connect each disk to a windows PC (USB or SATA).
- Open the windows disk manager (entering diskmgmt.msc on the run line will work).
- At the bottom of the disk manager window you will see each disk in the system. There's a graphic next to each disk that shows every partition (which Windows calls "volumes" for some reason).
- Right click on each partition in the graphic, and select "delete volume"
- Put all the disks back into the unpowered NAS and turn it on. It will do a factory install (since all the disks are blank).
- Jun 10, 2022Retired_Member
