MathijsKosters
Oct 10, 2011Aspirant
Many Networkerrors + Netgear Readynas duo hangs
Hi all, I've got the following problem: Yesterday I bought myself a new Readynas duo, so I installed it as in the manual. But when checked the webinterface (RAIDiator 4.1.8) works very very slo...
Oct 10, 2011Guru - Experienced User
Are you reading/writing data over wireless or 100 mbit ethernet? If so, you might need to enable 802.3x flow control. (There are other possibilities, including a bad cable or switch port.)
MathijsKosters wrote: Hi all,
But when checked the webinterface (RAIDiator 4.1.8) works very very slow, loading a page costs about 5-10 seconds.
When I checked the NetworkErrors in the RAIDiator I got plenty:
60 incorrect packages
40 TCP-retransmissions
10 Not-recovered TCP-retransmissions
When I reseted the log and watched 10 minutes later I got about the same errors.
But that's not the only thing. Sometimes when I write something to the NAS, the write-proces stops and the NAS becomes unreachable.
What's wrong? Something in my router or something?
I hope you can help me out!
Greetings,
Mathijs
What router are you using?
