MathijsKosters
Oct 10, 2011Aspirant
Many Networkerrors + Netgear Readynas duo hangs
Hi all, I've got the following problem: Yesterday I bought myself a new Readynas duo, so I installed it as in the manual. But when checked the webinterface (RAIDiator 4.1.8) works very very slo...
Oct 10, 2011Guru - Experienced User
In managed switches you can turn this on/off. Generally in routers and unmanaged switches it is hard-wired (on or off). I'm not seeing any manuals for your router on line (at least not on English sites), so I can't tell what your situation is. If you have a datasheet or manual, check the technical specs and see if 802.3x is listed.
MathijsKosters wrote: btw. Where in my router can I enable the 802.3x flow? Can you give some more detailed information?
I suggest that the next step is to connect your mac with ethernet and see if the stats improve. There are some other tweaks for WiFi (particularly MTU size), but before you go there you should get the basic wired network working reliably.
