MathijsKosters
Oct 10, 2011Aspirant
Many Networkerrors + Netgear Readynas duo hangs
Hi all, I've got the following problem: Yesterday I bought myself a new Readynas duo, so I installed it as in the manual. But when checked the webinterface (RAIDiator 4.1.8) works very very slo...
Oct 10, 2011Guru - Experienced User
Frontview is pretty sluggish on the DUO - mine takes a few seconds to come up if the disks are spun up.
MathijsKosters wrote: Thanks for your help so far. I've tried exactly the same with ethernet but that doesn't make any difference. How fast is the web interface normally? Do you have any other suggestions for me?
The best way to measure speed is to time a fairly large file transfer (something around 500 Mbyte - 1 Gbyte file), then you can measure the throughput. Test this separately in both directions (read times will be different from write). Maybe you should clear the network stats before the test, and record the network errors you get.
BTW, do you have jumbo frames enabled on the DUO? Is the MTU size set to the normal 1500 bytes? (Just asking, not suggesting any changes just yet).
