mito1
Jan 18, 2012Aspirant
md5 check program for ReadyNAS Ultra
Hi there, I've been looking for a programm that can check md5-sums on the ReadyNAS itself. I create md5-sums on my PC and copy the backup-files an the md5-files to the NAS. After that I check it wit...
mdgm-ntgr
Jan 19, 2012NETGEAR Employee Retired
It's also possible that md5sum doesn't like the * on each line of the list.
I think the command you should use to create a new md5-file with this change is something like
Or better yet, perhaps you could do a command to replace a space followed by an asterisk with just a space.
As your filenames include spaces you will also want to put quotes around them. You could use a command to replace just the first space in the line with a space + quotation mark (") and add another quotation mark to the end of each line. There should be commands to do these changes as well.
sed 's/\*//g' md5-file > new-md5-file
