Bob-Burton
Mar 19, 2016Aspirant
me too: [ReadyNAS Pro 6 Checking root FS]
Hi, I have the exactly same problem as described in https://community.netgear.com/t5/Using-your-ReadyNAS/ReadyNAS-Pro-6-Checking-root-FS/td-p/1046700. My (legacy) ReadyNAS Pro 6 is running OS...
Bob-Burton
Mar 30, 2016Aspirant
a (short) update on this:
-mdgm spent much time in investigating the problem but wasn't able to solve it yet (Thanks a lot for this!)
-meanwhile I was able to mount the data partition via tech support mode and rsync all files to an external storage
-kernel messages and log files indicates that the root cause for the problems could be some minor filesystem corruptions on the btrfs on the data partition
-as there is no risk to lose data, mdgm recommended to factory reset the system to get a clean state
-I am not willing to do the reset now - not until I've done some further research (I maintain several ReadyNAS instances (>10) and would like to know if there is an other solution than a factory reset.
Just in case I will fail on this: what would a complete factory reset do? To which firmware version would it bring back the system? To the *original* factory default (Raidiator 4.0.1 IIRC) to the latest Raidiator 4.2.27 or to OS6 version 6.4.1?
Is there a way to tell OS6 to initially build a RAID with dual redundancy?
Thanks
Bob
Mar 30, 2016Guru - Experienced User
A factory reset will install the firmware currently on the NAS. Whenever firmware is updated, the flash is updated too (as well as the OS partition).
The way to create dual redundancy is to immediately switch to flex raid after install, then destory the data volume. Create a new one as raid-6 and then switch back to xraid. Note you do not need to wait for the initial volume to be built.
- Bob-BurtonMar 30, 2016Aspirant
Thank you for the clarification.
Bob
- StephenBMar 30, 2016Guru - Experienced User
This is the OS6 procedure.
OS 4.2.x is simpler. You tell the system to use the next disk for redundancy before you insert it.
