Scubbie
Jun 02, 2012Apprentice
Missing items in Ultra 6 Plus GUI Menu
Hi folks, I'm currently setting up a new NAS (RNDP600U) and notice that the option to upload add-ons is missing. I have the ReadyNAS Ultra Duo as well and would like to add a few of the add-ons ...
Scubbie
Point taken about the older firmware. I bought the Duo back in September so I know that 4.2.19 has been around since before then. There is a label on the underside of the NAS that indicates the model & serial numbers, etc. It doesn't indicate when it was made though. I have the original packaging but removed all the shipping labels, including those from Netgear to where I bought it from.
I had thought about this but I currently have enough material to fill the 12GB capacity that this would provide me with and no room for any increase. The sinredundancyency should be fine for my requirements. The fact that I have bought half the drives now, with the remaining in a few weeks, possibly from another source (price dependant), should prevent dual failure foccurringring. Murphy's law suggests that this will happen now :roll: .
Once the data migration has been completed I will be free to wipe the Duo and use that for backing up the more critical content. and possibly a few other tasks too.
mdgm wrote: I'd recommend you choose to use dual-redundancy. See http://support.netgear.com/app/answers/detail/a_id/19044/~/converting-and-xraid2-system-to-dual-redundancy
