ifixidevices
Jan 28, 2016Luminary
Moved drives from Pro 6 to Ultra 6 in same order, volume now missing
I thought if you had the same firmware installed on an intel unit you could move from a pro 6 to an ultra 6 as long as you kept the disks in the same order. I did just that and upon boot up it says r...
Jan 28, 2016Guru - Experienced User
That migration should have worked.
