ifixidevices
Jan 28, 2016Luminary
Moved drives from Pro 6 to Ultra 6 in same order, volume now missing
I thought if you had the same firmware installed on an intel unit you could move from a pro 6 to an ultra 6 as long as you kept the disks in the same order. I did just that and upon boot up it says r...
mdgm-ntgr
Jan 28, 2016NETGEAR Employee Retired
ifixidevices wrote:
It's also frustrating because I feel like a wealth of information could be shared to help out in these instances but it all is hidden under the "contact netgear support"...
When it comes to situations where one needs to proceed carefully, it is best handled by support. Obviously that's not possible in this instance as your are running OS6 on a legacy device.
I have sent you a PM.
