WingDog's avatar
WingDog
Guide
Jul 21, 2015
MPIO - slow speed
Hello!
I have two ReadyNAS6 Pro boxes with the following configs:
1 box
RDN6 pro/E7300/4gb/6*2Tb WD CB/4.2.27 FW
2 box
RDN6 pro/E5300/2gb/6*2Tb WD CB/6.3.5 FW
Other equipment:
Juniper EX3300 switch and Dell R510 server
R510 is Hyper-V 2012 R2 server for lightweight load  with MPIO enabled.
I'm using SQLio to check iSCSI storage speed and latency.
while any tests I got only ~110MB/sec storage speed with 2*500mbps load at dedicated iSCSI NIC (taskmgr) with any NAS.
mpclaim show LB policy as RRWS (it seems to be correct, but RR only is unsupported??!) with two active paths, so MPIO configured correctly.
But PRTG monitor shows ~92-95% load at first NIC and ~10-15% at second NAS NIC, so why I guess there is some MPIO error with NAS config.
So, the question is: how to achive 2*1gbps speed using MPIO with ReadyNAS?
  • BrianL2's avatar
    BrianL2
    NETGEAR Employee Retired
    Hi Wingdog,
    How many active NICs are you using in your ReadyNAS system?
    Kind regards,
    BrianL
    NETGEAR Community
      • mdgm-ntgr's avatar
        mdgm-ntgr
        There are some good tips re MPIO here in the "Configure multiple MPIO sessions to the Target" section
        With MPIO the key is have the 2 nics on separate subnets. Otherwise you cannot be sure that layer 2 gets it right
ProSupport for Business
