KillerBob
Feb 22, 2012Aspirant
My Book via Ethernet
Hi,
Looking for a new backup solution, I found large Ethernet based HDs at a reasonable price and performance. So, if I get one of these, can I connect it via the 2nd Ethernet connection in my Pro, and backup to it? And, would the performance be better than via USB?
Thanks for any feedback!
Bo
Bo
- KillerBobAspirantHi mdgm,
Thanks for the confirmation. But how do I then use the second disk when I finally get it? Can I dedicate where shares are created? I have only ever used XRaid, and Flex is new to me. The reason I am eager to start using my Ultra 1 is that it'll be days before I get disk #2, and I have a lot of backing up to do...
Bo - mdgm-ntgrNETGEAR Employee RetiredYes you can choose which volume to create shares on.
However bear in mind that if you wish to use the Time Machine feature enable via Frontview on this NAS it will use volume C. - KillerBobAspiranthmmmm
I have the Ultra 2 setup as "Volume C: Online, RAID Level 0 , Single disk, 35% of 2768 GB used", and I decided to try it all out, so I took at old 500GB disk and shoved it in....and nothing happened. I see it in the Health overview, but under Volume settings, I only see "Configuration: RAID Level 0, Single disk", and "Status: Not redundant. A disk failure will render this volume dead.", and there is no listing for a second volume???
Is there something special I have to do? I thought it would be recognized automatically, and I would get a prompt.
Bo - KillerBobAspirantDon't worry! Got it. Total brain fart!!! Didn't even see the tabs at the top:)
- KillerBobAspirantAll,
Just want to finish this saga;
I caved in and picked up the last disk for the Ultra somewhere else, and followed the directions from mdgm (thanks for your help). It worked flawlessly, and I am now the happy owner of an Ultra 2 for backing up my Pro. It is fast too, do I am a happy camper...
Bo
