Helens
Oct 27, 2015Aspirant
my username & password are not recognised
I have a readynas Duo v2. When logging on to it through RAIDar or the ip address I get an error message to say that my username and password are not recognised, or the log in screen just reappears, a...
- Oct 27, 2015
What firmware are you running? Is SSH enabled?
You could try an OS reinstall (which resets the admin password to factory default, and also reconfigures the network to use DHCP). But perhaps wait for Netgear folks to chime in, they might have some other possibilities to try first.
Oct 27, 2015Guru - Experienced User
- HelensOct 27, 2015Aspirant
Thanks for your reply. I'm using Raidiator Arm, on a version earlier than 5.3.11. (does that sound right?) I can't access anything, so can't actually check, I'm just trawing through old downloads to see what I last had (5.3.11 wouldn't install, so I know it's ealier than that). SSH? sorry, what's that? Basically I set this all up and it's been trouble free untilthe last few weeks.
- StephenBOct 27, 2015Guru - Experienced User
SSH is a command line interface into the NAS. Probably not for you (since you don't recognize it).
Perhaps someone from Netgear might offer to take a look. If they don't, then support.netgear.com is probably your best option (though they will likely charge).
- HelensNov 04, 2015Aspirant
I tried restting the OS to factory settings and it has worked immeidately. Thanks for your help.
