Singularity
Oct 05, 2011Tutor
Naming convention for Folders and Files
Is it best to always use lowercase for naming folders and files on the ReadyNas. Also is it best to avoid spaces and maybe use the underscore (_) or full stop (.) instead. instead of my folder fi...
Singularity
Oct 05, 2011Tutor
ok thanks for that.
I more or less had my folders/files named in that way anyway, but now I've modified them totally to comply with your suggestion.
I have a series of programmes called 'Magic Harbours'. There are only 6 in the series but unfortunately Plex has chosen the incorrect metadata and artwork. I've modified the metadata easily enough but cannot see how to change the artwork. I've obtained some suitable jpeg images I want to use for the background and folder but cannot see how I install these. I've tried to drag and drop but that doesn't work so any other suggestions would be welcome.
Cheers
Cheers
