Singularity
Oct 05, 2011Tutor
Naming convention for Folders and Files
Is it best to always use lowercase for naming folders and files on the ReadyNas. Also is it best to avoid spaces and maybe use the underscore (_) or full stop (.) instead. instead of my folder fi...
sphardy1
Oct 05, 2011Apprentice
Plex primarily used on online community database thetvdb.com to look up TV shows. As you will see from this link there is no entry for the show you mention, which would explain the mismatch:
http://thetvdb.com/?string=magic&search ... ion=Search
The *best* solution is for you to create a login @ thetvdb.com and add the show - that way everyone benefits and artwork & metadata will be picked up automatically
