Singularity
Oct 05, 2011Tutor
Naming convention for Folders and Files
Is it best to always use lowercase for naming folders and files on the ReadyNas. Also is it best to avoid spaces and maybe use the underscore (_) or full stop (.) instead. instead of my folder fi...
Singularity
Oct 05, 2011Tutor
I've modified the folder structure for my files and now run into a problem.
I've laid out my folders like you suggested which I read from Plex was the suggested way.
e.g.
/c/media/TV Shows/Lewis/Season 1/Lewis - S01E1 - episodename.avi
/c/media/TV Shows/Lewis/Season 2/Lewis - S02E1 - episodename.avi
/c/media/TV Shows/Lewis/Season 3/Lewis - S03E1 - episodename.avi
In the TV show section box I had the path to the folders as
Then when Plex scans the files it displays separately the folder names.
Season 1
Season 2
Season 3
These should be within a Lewis folder but they are not. Also because it's not looking for Lewis it doesn't display any programme data or artwork.
The problem cropped up when I sub-divided my folders into seasons.
Any thoughts....
e.g.
Season 1
Season 2
Season 3
Any thoughts....
