Singularity
Oct 05, 2011Tutor
Naming convention for Folders and Files
Is it best to always use lowercase for naming folders and files on the ReadyNas. Also is it best to avoid spaces and maybe use the underscore (_) or full stop (.) instead. instead of my folder fi...
Singularity
Oct 06, 2011Tutor
Hi again
Set my folders out as you suggested and now working ok. Thanks for your help.
By the way...
I have several hundred films in my movies folder and when searching the films with say Plex client on my iPad it takes ages to scroll through all the films. On the iPad client there is an option to view unwatched films. Do you know how I set a film as 'watched'.
Cheers
By the way...
Cheers
