Singularity
Oct 05, 2011Tutor
Naming convention for Folders and Files
Is it best to always use lowercase for naming folders and files on the ReadyNas. Also is it best to avoid spaces and maybe use the underscore (_) or full stop (.) instead. instead of my folder fi...
sphardy1
Oct 08, 2011Apprentice
When setting up a section in the library you can specify a "Personal Media" agent is used for scanning. This will pull data only from the video files rather than look up data from the Internet. I *think* this will give you what you want.
