tikitiki
Jan 28, 2018Aspirant
NAS Constantly Uploading Something
Hi My NAS is constantly uploading something at significant speed and I cant work out what I can see via my router that the NAS has an ongoing upload speed about 10-30Mbps and its uploading ab...
- Feb 07, 2018
Netgear have found the issue
It was the dropbox api and an issue with the time stamping of files (thats all the info I have)
tikitiki
Feb 05, 2018Aspirant
Update:
It is the Dropbox sync causing the upload issue
I tunrned the dropbox sync off and looked at my router upload speed and it was still showing 30 mbps uploading. However the sync seems to take some time to stop as i turned the sync off for a couple of days and my daily upload volume dropped to less than 100Mb. The first time in about 6 months. I turned the sync back on and my daily uploads increased back to Gb's per day.
So why is this dropbox sync uploading Gb's of data each day if the data isnt changing?
Plus I meant to say I have the snapshots service working on the NAS, not created shares. Apart from the snapshots and the anti-virus enabled its a fairly standard set up.
- Marc_VFeb 07, 2018NETGEAR Employee Retired
Hi tikitiki
Welcome to the community!
Have you checked the full logs? Can you check what's in the dropbox log file.
You can send a PM of a download link thru dropbox if possible.
Regards
- tikitikiFeb 07, 2018Aspirant
Hi
The logs dont show anything unusual - unit powers on and off, hourly snapshots taken, etc. No network activity of any kind is listed.
Someone from the Netgear support team has contacted me and they are having a look at the issue via the Diagnostic Mode. The NAS is currenlty uploading at 45Mbps so if they are listening they should be seeing something.
