Lololo
Jan 11, 2017Aspirant
NAS unexpectedly stopped responding
Hello, everyone! My NAS device unexpectedly stopped responding, there was an error message on its screen: "iscsit_handle_dataout_timeout+6". I've turned it off and then turned on, the disks are ...
mdgm-ntgr
Jan 11, 2017NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
Did you enable allowing password authentication when you enabled SSH? Did you remember to use the 'root' (no quotes) user which by default has the same password as the 'admin' user?
- LololoJan 11, 2017Aspirant
Hello, mdmg!
many thanks for your reply!
Now I've allowed SSH access to admin user. The question remained is how to check exact hardware version of the NAS?
Here are my logs:
Wed Jan 11 2017 10:59:01 Disk: Disk Model:WDC WD4004FZWX-00GBGB0 Serial:NHG719NN was added to Channel 4 of the head unit. Wed Jan 11 2017 10:55:51 Volume: Volume n-vol health changed from Redundant to Degraded. Wed Jan 11 2017 10:55:11 Disk: Disk Model:WDC WD4001FAEX-00MJRA0 Serial:WD-WCC130211243 was removed from Channel 4 of the head unit. Wed Jan 11 2017 10:44:33 Volume: Volume n-vol health changed from Inactive to Redundant. Wed Jan 11 2017 10:44:33 Volume: Resyncing started for Volume n-vol. Wed Jan 11 2017 10:43:13 System: ReadyNASOS background service started. Wed Jan 11 2017 10:43:13 Volume: Less than 10% of volume n-vol's capacity is free. Performance on volume n-vol is degraded. To improve performance, you must add capacity. Wed Jan 11 2017 10:43:11 System: ReadyNASOS service or process was restarted. Wed Jan 11 2017 0:59:22 Snapshot: Snapshot prune worker successfully deleted snapshot 2016_12_14__00_00_12 from share or LUN ShpTempBackupStorage. Wed Jan 11 2017 0:00:18 Miscellaneous: Snapshot c_1484082017 was successfully created for share or LUN ShpTempBackupStorage. Tue Jan 10 2017 0:56:56 Snapshot: Snapshot prune worker successfully deleted snapshot 2016_12_13__00_00_04 from share or LUN ShpTempBackupStorage. Tue Jan 10 2017 0:00:18 Miscellaneous: Snapshot c_1483995610 was successfully created for share or LUN ShpTempBackupStorage. Mon Jan 9 2017 0:55:18 Snapshot: Snapshot prune worker successfully deleted snapshot 2016_12_12__00_00_00 from share or LUN ShpTempBackupStorage. Mon Jan 9 2017 0:00:21 Miscellaneous: Snapshot c_1483909213 was successfully created for share or LUN ShpTempBackupStorage. Sun Jan 8 2017 0:53:09 Snapshot: Snapshot prune worker successfully deleted snapshot 2016_12_11__00_00_13 from share or LUN ShpTempBackupStorage. Sun Jan 8 2017 0:00:45 Miscellaneous: Snapshot c_1483822810 was successfully created for share or LUN ShpTempBackupStorage. Sat Jan 7 2017 0:50:54 Snapshot: Snapshot prune worker successfully deleted snapshot 2016_11_12__00_00_02 from share or LUN ShpTempBackupStorage. Sat Jan 7 2017 0:00:21 Miscellaneous: Snapshot c_1483736400 was successfully created for share or LUN ShpTempBackupStorage. Fri Jan 6 2017 14:49:59 Snapshot: Snapshot prune worker successfully deleted snapshot 2016_12_09__00_00_21 from share or LUN ShpTempBackupStorage. Fri Jan 6 2017 14:49:37 System: ReadyNASOS background service started. Fri Jan 6 2017 14:49:36 Volume: Less than 10% of volume n-vol's capacity is free. Performance on volume n-vol is degraded. To improve performance, you must add capacity. Thu Jan 5 2017 21:03:49 System: The system is shutting down. Thu Jan 5 2017 9:29:05 Disk: Detected increasing uncorrectable error count: [13] on disk 4 (Internal) [WDC WD4001FAEX-00MJRA0, WD-WCC130211243] 13 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy. Thu Jan 5 2017 0:32:20 Snapshot: Snapshot prune worker successfully deleted snapshot 2016_12_08__00_00_11 from share or LUN ShpTempBackupStorage. Thu Jan 5 2017 0:00:07 Miscellaneous: Snapshot c_1483563606 was successfully created for share or LUN ShpTempBackupStorage. Wed Jan 4 2017 0:31:05 Snapshot: Snapshot prune worker successfully deleted snapshot 2016_12_07__00_00_01 from share or LUN ShpTempBackupStorage. Wed Jan 4 2017 0:00:25 Miscellaneous: Snapshot c_1483477224 was successfully created for share or LUN ShpTempBackupStorage. Tue Jan 3 2017 0:29:51 Snapshot: Snapshot prune worker successfully deleted snapshot 2016_12_06__00_00_06 from share or LUN ShpTempBackupStorage. Tue Jan 3 2017 0:00:17 Miscellaneous: Snapshot c_1483390815 was successfully created for share or LUN ShpTempBackupStorage. Mon Jan 2 2017 0:28:38 Snapshot: Snapshot prune worker successfully deleted snapshot 2016_12_05__00_00_00 from share or LUN ShpTempBackupStorage. Mon Jan 2 2017 0:00:08 Miscellaneous: Snapshot c_1483304407 was successfully created for share or LUN ShpTempBackupStorage. Sun Jan 1 2017 0:27:15 Snapshot: Snapshot prune worker successfully deleted snapshot 2016_12_04__00_00_21 from share or LUN ShpTempBackupStorage. Sun Jan 1 2017 0:00:28 Miscellaneous: Snapshot c_1483218027 was successfully created for share or LUN ShpTempBackupStorage. Many thanks to you!
- StephenBJan 11, 2017Guru - Experienced User
What is on the label?
- LololoJan 12, 2017Aspirant
Hello, Stephen!
What do you mean - "on the label"?
Please, explain.
Do you have any ideas about my first question: why my RN316 stopped responding with "iscsit_handle_dataout_timeout+6" message?
Thank you.
