Avorill
Nov 22, 2012Aspirant
Need help with Factory Reset.
Hi. I need to do a Factory Reset without HDD so it will be in the same condition as I got it because I am returning it back to the store. How can I do the Reset without putting in any hdd's pls h...
Nov 22, 2012Guru - Experienced User
You can't, but you don't need to. The only thing that might have changed is the firmware install stored in the flash, and it should be ok if that is newer. Everything else is in the OS partition on the hard drives.
Avorill wrote: Hi.
pls help me someone.
