jay_johnson
Aug 13, 2013Aspirant
Need Updated Info for iSCSi installation in 5.1 ESXi
I was trying to install iSCSi support on my 5.1 ESXi host and noticed that the option for installing iSCSi datastores located on the readynas has changed. I was following along with this document up ...
mdgm-ntgr
Aug 13, 2013NETGEAR Employee Retired
There is an issue with 4.2.21 on 32-bit systems such as the NVX which means you should update to 4.2.24. Certainly if you wish to expand your volume you should update to 4.2.24 before adding disks.
