Anonymous
Nov 22, 2012netgear nv+ a sata reset has occured
I've a Netgear NV+ with 4 western digital (caviar green) 2tb harddisks . I've bought this in 2010. It always worked fine, till last week.I had to reboot the system a few time. (the netgear was not app...
Nov 22, 2012Guru - Experienced User
I think you should open an on-line support case.
Did you insert the new disk with the system running?
BTW, if you buy more new disks for your NAS I'd recommend getting the new WD red drives instead of the green.
