Retired_Member
Nov 22, 2012netgear nv+ a sata reset has occured
I've a Netgear NV+ with 4 western digital (caviar green) 2tb harddisks . I've bought this in 2010. It always worked fine, till last week.I had to reboot the system a few time. (the netgear was not app...
Nov 22, 2012Guru - Experienced User
The red drives are also pretty energy efficient (they have the same IntelliPower disk rotation stuff as the green drives).
You might check with your seller, you should at least be able to exchange the new one.
