cheztaz
Mar 16, 2013Follower
Netgear Readynas Duo Password reset.
Good afternoon. I have recently bought a netgear readynas duo and set it up ok! I did not save the username and password, and have tried to access it via the password recovery, and it says it will...
Mar 16, 2013Guru - Experienced User
Your other option is to do an OS reinstall. That preserves your data and settings, but will also reset the admin password to factory default and the IP configuration to use DHCP.
There's a guide here: http://www.readynas.com/kb/faq/boot/how ... boot_menu; you can also check your hardware manual.
