rekop
Mar 11, 2012Follower
NETGEAR READYNAS ULTRA 4 with WD30EZRX
Hi Will the Readynas ultra 4 be compatible with the HDD Western Digital Caviar Green WD30EZRX. WD30EZRX is really affordable compared to Western Digital Caviar Green WD30EZRS. Any "to be listed...
ReadySECURE
May 11, 2012Apprentice
Since these drives are not on the supported list, Netgear will not provide support for them. This doesn't mean they wont work. It just means Netgear may ask you to remove them from your ReadyNAS if they think they are the cause of a problem. From the link j0ker provided it looks like there is at least one company confident that they do work. I would be very cautious anytime you are looking at getting drives not on the supported list especially green drives which don't tend to handle the stress of a raid well.
