toby30938's avatar
toby30938
Network Issue between ReadyNAS and Router (AVM FritzBox 7490)
Hi there,
we recently moved from an "old" Ultra2+ towards RN312. Migration was fine.
But we have a major issue with our internet connection (Router is an AVM FritzBox) now. The connection runs well for around 9hours and then brakes every 2-3 min. It must be related to the RN312 somehow, because when we shutdown the 312 the connection ist fine again for the 8-9 hours. I can´t find anything in the logs from the 312 or the router which leads me to solve the problem. Right now i do an automatic shutdown/ restart in the morning.
Any idea concerning that topic?
Cheers
Tobias
  • StephenB's avatar
    What firmware are you running?  Also, can you list the services and apps that are enabled/installed?
    You might also try disabling IPv6 in the NAS
    • toby30938's avatar
      toby30938
      Firmware is newest available, 7.5.something afaik?! There are no apps at all installed, no antivirus enabled, no IPv6 enabled (also disabled on the router). Services only smb, http, https, nothing else. I tried to elimate all possible causes, but nothing I could think of helped.
      • StephenB's avatar
        You must mean 6.7.5 (current production release).
        ReadyCloud is also off?
        These traffic bursts are unusual.  The NAS will sync with the NTP server from time to time, and it will occasionally try to update from Netgear repositories (which is silent, and doesn't change the firmware version).
        You could try removing all DNS servers, or possibly try misconfiguring the gateway IP - both would prevent the NAS from reaching the internet, but keep it on your local network.
  • You could use tcpdump to sniff the traffic. You just need to install and use through command line.
    apt-get install tcpdump
    As long as you are comfortable with the cli :)
    • StephenB's avatar
      I was just thinking an app to take a trace might be handy sometimes.  tcpdump is probably the right tool, since it outputs via pcap
        toby30938
        Latest update. I switched the gateway to something stupid and it worked out the whole weekend. So it looks to me, that something from the 312 is messing up the router. I can leave it that way for some time, but a long term solution would be nice :)
        Anyhow, thanks for the hint. I would not have thought of it...
ProSupport for Business
