Tithen
Oct 11, 2016Aspirant
NFSv4 and external drives
Hello! I've an interesting problem I do not understand, which have persisted through all of readynas OS 6, now also on 6.6 I'm using NFSv4, which works fine with my setup until I attach USB d...
- Oct 11, 2016
The problem did exist prior to 6.6, I can not pinpoint when it started to occur. It was regardless of the choice of USB port, (had two drives attached, attaching only one did cause the error). The SMB worked fine, also manually mounting the NFS share instead of NFSv4 worked.
However, I seemd to have found a solution. I turned off all nfs and turned them all back on (and made sure the /etc/exports was empty). Something in the setup most have been wrong since everything seems to be working as intended now, even after reboots.
Sucess!
JennC
Oct 11, 2016NETGEAR Employee Retired
Hello Tithen,
Did this happen even prior to updating to 6.6.0?
Have you checked if you get the same problem when you use other USB ports of the NAS? How's the SMB access when this happens?
Welcome to the community!
Tithen
Sucess!
- JennCOct 11, 2016NETGEAR Employee Retired
Hello Tithen,
Well, must be something just needed sometime?
It's good to hear it works now.
