stopgapit's avatar
stopgapit
No access to admin webinterface during raid rebuild
The readynas 104 web interface has died during data rebuild, i can ping the device but no web GUI.
The LCD display status: Booting     ( for last 2 hours )
It's running firmware 6.4.2
 Action performed: Rebooted the unit but it's in the same state and blue led is blinking rapidly with lcd display "booting"
  • BrianL2's avatar
    BrianL2
    NETGEAR Employee Retired
    Hi stopgapit,
    I suppose that you can't also access your files. If you want to access or backup your files,boot the unit in volume read-only mode. Also, can you tell us the most recent changes you made on your system that might have caused this?
    Kind regards,
    BrianL
    NETGEAR Community Team
    • mdgm-ntgr's avatar
      mdgm-ntgr
      Getting stuck on booting could also possibly indicate there is another failed disk. Did you check the SMART stats of the disks before adding/replacing a disk?
ProSupport for Business
