Hplar_H
Mar 08, 2022Aspirant
no volumes after blackout on Readynas Duo V2
Ready NasDuo v2 with Radiator 5.3.13 with originally 2 HDD (X-Raid2) After a power outage in the neighbourhood the NAS lost access to the volumes. I have seen similar posts, but not a solution i...
- Mar 08, 2022
ReclaiMe is expensive (in part because it supports BTRFS). Another tool you can try is R-linux for Windows (which is free). https://www.r-studio.com/free-linux-recovery/
Have you tried simply booting the NAS with only disk 2 installed? If that fails, you could try again with only disk 1 installed (powering down before moving disks).
It is important to clarify the model - many v1 owners mistakenly think they have a v2. Does your NAS say "ReadyNAS Duo v2" on the front panel?
Hplar_H
I started to run photorec which comes with testdisk 7.1 but stopped it after a while seeing that the file structure and names etc are not recovered.
I also triedReclaiMe (not purchased yet), which shows a Linux md-raid volume of the correct size. But the program freezes after 0.02% of the search (and finding 2 files)
I tried EaseUS Data recovery Wizard 15 (testversion), file recovery search brings up a list of more than 4TB of various files, but also a lot without any structure/name/timestamp. But the preview brings some of the files I am looking for. I also tried the NAS recovery but also no success. I think this tool is connecting to the NAS but the required services are not performed…at least it stops with an error.
I would really like to know, if it could be possible to get the volumes back or not. I have a backup from 6 month ago. So data-recovery with 4 TB of data without structure and proper timestamps won’t help me….
Any Idea what could be possible?
Mar 08, 2022Guru - Experienced User
- Hplar_HMar 08, 2022Aspirant
Thanks Stephen,
I’ll have a look into your proposed solutions.
It is certainly a V2, as I had a V1 before and upgraded to use larger HDD (now having two WD red 4TB in (WD40EFRX)).
Stupidly, I managed to write something wrong into the partition table of one of it with testdisk on my initial tries (without having a backup of the previous layout). So, at the moment the NAS is accepting one HDD only – however, not showing up volumes. I think I had it in both slots already, but I will give it another systematic try.
If i would like to undo my mistake....could I insert the “modified” one with the one with an intact partition table, and the NAS synchronize/mirror the “intact” one onto the modified one? Or would it be better trying to modify the partition table of the “modified” on to match the intact one again?
- StephenBMar 09, 2022Guru - Experienced User
If you hot-insert the modified disk 1, the NAS will sync it with disk 2. That will resync every sector. If you get disk 2 to boot (with the volume), then I'd go this route.
Though if disk 2 won't boot with the volume, then repairing the partition table is probably the better approach, as it gives another chance to get the volume back.
- Hplar_HMar 09, 2022Aspirant
Thanks Stephen,
very good answer how to approach my mistake . About the way I was thinking. Unfortunately the untouched disk would not boot with the volumes in both slots.
Anyway, in the meantime, the R-Linux was able to read and recover the file structure from the untouched disk. I think I recovered all files and folders now (unfortunately also a lot of "garbage" on top : attribute files, deleted files etc). But this will allow me to find those files not in my clean back-up (from half a year ago). Thanks a lot for the hint with R-Linux again!
BR Ralph
