elinenbe
Dec 05, 2009Aspirant
NV 4x1TB -> 4x2TB nightmare! (#10777660)
Here's what I have done so far
I have a readynas NV
It has 4x1TB (xraid) 4.1.6
1) I bought 4 new 2TB drives
2) Replaced each drive one at a time
3) Rebuilt successfully after each drive replacement
4) RAID begun expansion after 4th drive was put in.
5) Never properly expanded
6) Found out I had the wrong block size so, I would need to do a factory reset (a very old device)
7) Backed up ALL data to external hard drives
8) Factory reset
9) Rebuilt okay
10) Restored old config
11) Became unresponsive
12) Factory reset again -- unresponsive -- says root corrupted
13) USB reset -- looks like it works.
14) reboot, I get two LEDs blink, then four LEDs, then two, etc...
15) check dimm -- seated okay
15) try tFTP reset -- loads up okay
16) upon reboot, it never comes back up.
17) reboot, I get two LEDs blink, then four LEDs, then two, etc...
18) USB reset -- looks like it works.
19) reboot, I get two LEDs blink, then four LEDs, then two, etc...
Please help. These are new drives, and work fine outside of the NAS with no problems. I'm at ends wit!
Thanks,
Eric
8) Factory reset
9) Rebuilt okay
Thanks,
Eric
- elinenbeAspirantSo, the technician, remotely accessed my unit, and I had just rebuilt the 4x2TB XRAID array, and he logged onto it and found this:
"We have remotely logged into your device and checked the integrity of the system. The device shows no improper shut down events and there currently is no evidence of the root file system being corrupted."
So, I then rebooted the device from maintenance mode (TELNET in RAIDar), and sure enough it came up "Corrupt root"
The tech then, got back on the device and found this:
"After looking into your device I see an error with the unit mounting the volume after a successful XRAID start. In this case the issue resides with the device hardware, as such there is nothing further we will be able to do. The final option is replace the hardware. Unfortunately this device falls outside hardware warranty therefore we will be unable to replace it."
Funny how everything now works 100% as a XRAID 4x1TB (spent ~7hrs working on this today). I can't believe I'm still dealing with this after more than a month. Clearly there is an issue with the software that needs to be fixed.
Can anyone from Netgear help me out here?
ps. I've also tried four other sticks of memory (even though the one in there worked fine for the past 4 years). - Ryan_AspirantDid you ever get this fixed? I was wondering if your 2TB drives worked OK if you did?
- chesirecat1AspirantAre st32000540as drives supposed to be compatible with an Ultra?
- mdgm-ntgrNETGEAR Employee Retiredchesirecat1 that is completely off topic. Have a look at http://www.readynas.com/hcl
Any drive on the list is approved for use. If not on the list then it is not approved for use. - chesirecat1AspirantI only ask here because that's the drive the OP had. The list is useful, but it does not include discontinued drive models that may have once been on it. This thread is the only search result for that model number and it's missing the usual discussion as to whether or not the drive is compatible.
- mdgm-ntgrNETGEAR Employee RetiredThe drive may/may not work. If you have issues with it, support will be denied.
If a drive is added to the list it is not removed simply because the drive is discontinued. It's likely the drive you mention was never added to the list in the first place.
