Reinier2110
Sep 12, 2012Aspirant
NV+ factory reset
I have made a giant mistake. Here's what happened: I forgot my password to enter the frontview of my NAS, so i tried password reset. Appears i never set the thing, so next option was a factory reset...
Sep 13, 2012Guru - Experienced User
If you let the factory reset complete I think the odds are really low. How much money are you prepared to spend? The more stuff you try (unsuccessfully), the more difficult the task becomes for a recovery service. So if you have any thoughts of using a service like that, you should contact them now - at least get a price.
Reinier2110 wrote: I really need to get the Photo's back
I haven't tried it either. However, if you can't afford a professional service it might worth a shot. You'd need to have at least two of the disks accessed by your PC. Perhaps you can contact them (or post on their forum).
Reinier2110 wrote: Do you think this is worth a try?
http://www.easeus.com/datarecoverywizard/
From the specs you will need the pro version (http://www.easeus.com/datarecoverywizardpro/). The standard version doesn't support linux file systems.
