smartwombat
Dec 18, 2012Aspirant
NV+ FW 4.1.7
I have a new NV+, with a label underneath "FW 4.1.7" I have a set of disks, from a NV+ that was upgraded to Raidiator 4.1.10. Will the two work, or do I have to convince the NV+ to update its firmwa...
Dec 18, 2012Guru - Experienced User
It will work, but if you ever do an OS-reinstall, 4.1.7 would be reinstalled.
That probably isn't a big deal, and would be resolved when/if 4.1.11 is released and installed. But if you have a spare disk, you can install that first, then update the firmware. Then power down, and substitute your existing disks.
