smartwombat
Dec 18, 2012Aspirant
NV+ FW 4.1.7
I have a new NV+, with a label underneath "FW 4.1.7" I have a set of disks, from a NV+ that was upgraded to Raidiator 4.1.10. Will the two work, or do I have to convince the NV+ to update its firmwa...
smartwombat
So there is no way to upgrade the firmware without a working disk in the unit.
I'll get the spare 1T that was going in the windows desktop, initialise as XRaid 1 disk, then upgrade to 4.1.10
I go the impression from here viewtopic.php?f=7&t=68210 that it wouldn't work.
"by mdgm » Thu Dec 06, 2012 3:12 pm
It is very likely that the firmware in the flash is older than that on your array.
The firmware in the flash should be at least as new as the firmware on the disks."
But maybe that's for the NV and not the NV+.
