terrygh
Nov 16, 2012Aspirant
NV+ Rescan of media will not complete
Readynas nv+ purchased on Nov 18 2010 serial number <REMOVED BY MODERATOR> The problem with the nas is the rescan of the media will not complete. No media files show up on the network media player...
kiokoman
after installing ssh u must login with username: root, after that navigate with cd /var/cache/minidlna and delete the database. restart the server from the frontview and the readydlna should create the file as new
to make it short:
stop readydlna server from the front view
start putty (you just have to put the ip address of the nas with port 22 and select SSH and login to the nas with the username "root" (the password is the same you have for the frontview but the username is root and not admin))
rm *
logout
go to the frontview and restart del readydlna server
i hope it's clear
to make it short:
rm *
logout
i hope it's clear
