Jappert's avatar
Jappert
NV+ Stuck on (hangs on) Booting...
It's actually a RND 4000 v3 (RAIDiator 4.1.15) 4x seagate Barracuda 2TB. I think it's RAID 5 (I know I'm supposed to know, but I don't... not for sure anyway)
Hi there. My NV+ is stuck on Booting...Even with browsing the discussions on 'stuck on booting' voor similar devices, I'm stuck with the next step myself.
After it hangs, it will only power dwon by pulling the plug.  No remote acces possible.
I tried the booting with FW update option... that didn't work.... FW updated o.k. I guess, but it got stuck on Booting.... again.  Same thing for the Memory-test option. After the powering-down (pulling the plug again) I numberd the drives and ran them through Seatools on my PC, performing the Short Generic test. Numbers 1,3,4 passed OK. No. 2 makes some worrying clicking noises after being connected. Test won't run (stuck at 0% at first test, the 'outer scan'). I guess that disk is completely dead.
So what is next?
Most interested in saving data of course. (yes I do back up regularly, but even the most recent stuff is worth saving). Any advice greatly apreciated.
Jasper
  • You could also see if it boots with the bad disk removed.
    • mdgm-ntgr's avatar
      mdgm-ntgr
      NETGEAR Employee Retired
      • Jappert's avatar
        Jappert
        Yessss...  that worked... Booting with the bas disk removed.   (Booting with "skip volume check" didn't;  it got stuck in the 'booting....' phase again) .
        Much, very much appreciated...
        (doing the extra back up right now...)
        Could I also slip in a new 2T drive in slot 2 and have the system 'healthy' again, or is that too optimistic?
ProSupport for Business
