Craigatitus
Mar 23, 2014Aspirant
NV+ v2 Volume Size after factory reset
Hello I have a NV+ v2 that had 4x3tb drives running in xraid2. I recently swapped out two of the 3tb drives for 4tb drives one at a time and let them sync successfully. After the second 4tb drive...
Mar 23, 2014Guru - Experienced User
Generally there are two phases to the creation of the array. First it is building a 4 x 3TB RAID5 layer (which results in the 8381 volume). When that is finished, there will be a reboot, and then a 2 x 1TB RAID-1 array is added to the volume, giving you the final TB.
