Craigatitus
Mar 23, 2014Aspirant
NV+ v2 Volume Size after factory reset
Hello I have a NV+ v2 that had 4x3tb drives running in xraid2. I recently swapped out two of the 3tb drives for 4tb drives one at a time and let them sync successfully. After the second 4tb drive...
Craigatitus
Great, that is exactly what I wanted to hear. I just hope that the second array building doesn't fail like the previous expansion attempts did before the factory reset.
Just a follow up question, should I be able to access the Dashboard right now while it is doing this first array building or resync? The dashboard loads but it says the device is offline.
Thanks
Craig.
Thanks
Craig.
