Craigatitus
Mar 23, 2014Aspirant
NV+ v2 Volume Size after factory reset
Hello I have a NV+ v2 that had 4x3tb drives running in xraid2. I recently swapped out two of the 3tb drives for 4tb drives one at a time and let them sync successfully. After the second 4tb drive...
Mar 24, 2014Guru - Experienced User
If it is still not available, perhaps you should contact support.
