Craigatitus
Mar 23, 2014Aspirant
NV+ v2 Volume Size after factory reset
Hello I have a NV+ v2 that had 4x3tb drives running in xraid2. I recently swapped out two of the 3tb drives for 4tb drives one at a time and let them sync successfully. After the second 4tb drive...
Craigatitus
Mar 24, 2014Aspirant
Well after the first resync I was able to access the dashboard (after clearing some cache settings) and it worked fine.
I had to reboot it twice before it started to run the second layer space allocation. Now it is running a resync and it is going at 1Mb/sec and it says 11 days remaining. I hope it speeds up because that is crazy slow...
Any experience with a resync taking this long? I think it is a little strange that it doesn't say volume expansion but rather just a resync. Even in RAIDar it says volume size is only 8687 GB
Thanks for your help so far.
Craig.
Craig.
