markgca
Apr 03, 2016Guide
NV+ will not boot - LED flashes
i have a NV+ that has been in constant use since 12/07 and is certainly out of warranty. Yesterday i had a power event (breakers were switched off and on a few times by someone who didnt know the...
vandermerwe
Apr 03, 2016Master
What firmware?
I would first try an OS reinstall using the boot menu. If this fails to improve the situation, then power down, remove all disks, insert a spare disk if you have one, then factory default the unit. This will assess the chassis integrity.
Before inserting the old disks, be sure to power down first, and insert them all in e correct slots.
- BrianL2Apr 03, 2016NETGEAR Employee Retired
Hi markgca,
Before trying to reinitialize your unit, you may want to try to perform "Skip volume check". If this won't work, try to boot up the ReadyNAS without any drives (assuming all are labeled or marked) and see if it will be detected by the RAIDar utility or by your network.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team- markgcaApr 04, 2016Guide
i had tried the OS reinstall before i posted (mistakenly called it a firmware update)
i did remove the drives, inserted a single new drive, and did a factory default; and it works fine.
so there must be something up with the drive set
i guess the next step is to reinstall the disks and perform 'skip volume check'? i had started the default before i saw your post.
but at least now i know the hardware is good.
thanks for the help. hopefully the unit will tell me which drive is bad
so it worked with the spare drive
replaced the original drives (in the original slots, they were all labeled) and it still stuck at booting
so i did the skip fs check, and it is still sticks at booting
any other ideas? if not i guess i just have to factory default the entire unit and start over. i should have a recent config so it isnt the end of the world, but it would be nice if i didnt have to do it.
[edit] i didnt see your reply until after i posted mine, sorry
it is default volume, so i guess thats xraid?
